First Oil Change
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Filling the oil filter before installing, does not work. As you point out, our filters on the 6.4 install side ways. From what I have read on this forum, other members have installed relocation kits, that do allow the filter to be primed/filled before starting.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
The 5.7 sits vertical, but I have YET to do an oil change without getting oil in my hair, on my power steering motor, up my arms, on my teeth and even the neighbors dog.
I never try to put oil in it first, I'd just make an even bigger mess, and.....
Not a single shop on the Planet Earth would do it either unless you insisted and stood there watching them with a baseball bat.
I just lube the o-ring and let it do it's thing.
Chief_6.7
Gotcha,
I did do the relocation kit on my truck to make it easier and cleaner to do my next oil change. I know on the kit it was an option to do horizontal or vertical. As far as priming that should not be necessary but if it helps you sleep at night I don’t see an issue with it
ripping r
Old&Grumpy
earth
6.4 HEMI
No its not necessary. but it does help get oil going faster. but i got the answer i thought i would. just cant really do it with the filter on its side.
thanks for the replys.
Orca
