Fluctuating Gas Mileage
Mfgilbert79
Albany, GA
6.7L Cummins
Hi all,
I’m new here so be gentle until I get my feet wet.
I’m driving a 2020 2500 6.7L Cummins.
I have been having wierd mph fluctuations on the computer. I go from 21-23mpg to 10-12mpg every couple of days in the middle of a drive. And once it falls down, it does not recover.
I have replaced the fuel filters and all other maintenance is up to date.
I was scrolling through the truck data while driving through this problem today and noticed while idling truck seems (I’m not sure about this just seemed high 1500ish I think)to be running a little high rpm wise. Also while coasting my boost gauge was showing 3-4lbs of boost.
Any ideas? Any post floating around about this here on the forums?
KKBB
Oakland Ia
My guess would be when you see the drop in MPG, or the high idle RPM the cummins is doing a regen.
yakalong
KC
Have you hand calculated your mpg or is this just per what the computer shows?
M
Mfgilbert79
Albany, GA
6.7L Cummins
Only what the computer shows. No I have no hand calculated the mpgs.
