Fog light issue
DennisD1975
Canada
So I installed my OEM fog lights, enabled them in alfaobd problem I have is the dash light comes on, but the lights do not. I used the Mopar harness and the harness from mpgrimm2. Any suggestions on what to check would be helpful. I have gone over all the connections and everything is correct and tight, but no lights. Not sure if I missed a step in the alfa setup, have reviewed it and it seems right. TIA.
White six four
Wisconsin
If everything is correct give it some time. Mine didn't work the first few times I drove it after installing them. Some time between the 3rd and 5th day they started working.
D
DennisD1975
Canada
So, now after waiting as White six four suggested the lights turn on for about 2 seconds and shut off and will not come back on unless I shut of the truck and restart it.
tron67j
Maryland
Have you reached out to Mike at M²Mods? He has built a number of the harnesses, perhaps he has run into this with another person.
