John Wauters
Does anyone know the part number the the fog light wire harness for a 2011 Dodge Ram 1500. I'm adding fogs to a ST. I need the harness that has the pins to go into the wiring harness with the ground wire eyelet. I seem to only find the harnesses with a black square connector and I'm not sure if that's correct or not as I can't find an answer to where that connects to on a 2011.
Any help would be much appreciated.
