Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
never heard of that law but so be it. Not like anyone is around when your using high beams unless your a *******. So i'm not quite sure why that would even be a law.
im sure i could simply wire a relay to the high beam
Wiring. JJ, through The Retrofit Source, offers a foglight correctional splitter harness that, along with a HID kit with relay harness, will allow you to run the fogs with the high beams on.
Most states do have laws against it and have to do with the wattage of lights and number of lights on. you can have as many lights as you want mounted but only 4 may be uncovered here in Cali and under 55watt.
Not sure they they still sell them but stylintrucks.com used to sell kits for older dodges and checvys, they may still have something
Believe it or not, The law in Alaska only states how bright they must be...
When a motor vehicle is driven on a highway during the times specified in sec. 10 of this chapter, the driver shall use a high distribution of light or composite beam, directed at a height and of sufficient intensity to reveal persons and vehicles at a distance of 450 feet in advance of the vehicle for all load conditions, subject to the following requirements and limitations:
I found a kit online, basically a relay that taps into the high beams and plugs into the fogs. I'm gonna install it this weekend sometime, I just don't feel like pulling the grill out to remove the head lights. Damn Chrysler engineers!
