jservay
Has anyone wired airhorns to the auxiliary switches? I'm looking to install the MotoHorn 3.0 using the auxiliary switch to turn on/off the MotoHorn between the OEM horn and MotoHorn. Ideally, I would like the steering wheel horn to operate both independently. When the auxillary switch is in the on position, it will activate the MotoHorn and off position, the OEM horn. I'm stuck on wiring up to the 5 post relay to get this to work. If anyone can post a wiring diagram, it would be greatly appreciated.
