for push start ram owners
Hemipower95
Just curious, what do you do if your key fob battery dies, and your stranded somewhere. You can still unlock it with the hidden key, but how are you supposed to start the truck?
kg93
AZ
pretty sure the push start button pops off and there's a spot for the key
jwheeler
Washington
The button does not come off. If the battery in the key dies, you just use the key to press the start button.
kg93
AZ
you sure? A friend who transports cars took a snapchat of him popping off the button and there was a spot for a key, it was a dodge though not not a ram
Edit: a friend**
jwheeler
Washington
I'm sure. Rams are different.
sbarron
Wasilla, Alaska
From the owners manual:
NOTE: In case the ignition switch does not change with the push of a button, the RKE transmitter (Key Fob) may have a low or dead battery. In this situation, a back up method can be used to operate the ignition switch. Put the nose side (side opposite of the emergency key) of the Key Fob against the ENGINE START/STOP button and push to operate the ignition switch and with your foot applied on the brake pedal.
kg93
AZ
Go figure they didn't cheap out and have the same design lol
Sent from my LG-H900 using Tapatalk
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
Wow, learn something new every day. Not sure how that works though.
DrewTZ
Minneapolis, MN
Thanks for digging this up, had worried about this as well.
scHemi
2009 RAM SLT Crew
What happens if it says defective key or something. Mine took one too many trips through the washer. Curious
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I really just want my key back...
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Then you are not a candidate for a key-less system. Seriously, that is two points of failure with one being your fault.
