Ford 302 oil filter adapter
diymirage
Banned
I picked one of these up and got no use for it
It is a 90 degree adapter for the Ford 302 small block that allows you to angle it out of the way for headers, swaps or just to make oil changes less messy
I think $25 plus shipping is fair (or come pick it up in Holland MI)
One note of caution, whoever build those decided to use the 3/4 thread to mount it, but changes the other end to 22mm thread
(Should also fit just about any other engine with the 3/4 oil filter stud)
diymirage
diymirage
Banned
Pics
ZFORCE
Tucson
6.7l Cummins Diesel
I’m interested in putting this on a 1995 mustang 5.0. I’m not sure what you mean by the other end is
ZFORCE
Tucson
6.7l Cummins Diesel
22mm? Do you mean it won’t accept a standard FL1 filter? Thanks
diymirage
diymirage
Banned
Correct, it will NOT take a FL1 anymore
The "other end" is the part where the new oil filter would screw unto, which is 22x1.50, same as our trucks take (in fact, I have a truck filter on there in the pictures, a fram PH2)
No idea why they did it that way, but there are companies who make 3/4-16 to 22mm oil adapters, but I would totally get it if you don't want to piece it together
Having said that, there has got to be a metric equivalent of the FL1 filter
