Fox vs King vs ICON front coilovers
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@JB1 I thought I was the only weirdo lowering my lifted truck. I'm glad I am in good company
JB1
Houston, Texas
Well I went from 37’s to the 325’s so I wanted to keep that same tire:fender gap ratio so I went down about 2” at each corner. I kinda miss being up high on 37’s but I like the new height. I’m still too tall to fit in the garage though, I’m at 43-1/2” front and 44-1/4” rear and I think the sharkfin was 84-3/4. I think our suspension height differences are due to the 325’s being a little taller.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Maybe taking a full lock U-turn and hitting a bump just grazes it. I would jack that tire up have a helper spin the wheel while you hold a piece of 80 grit sandpaper on the axle.
T JAZ
T JAZ
Glendale AZ
hemi 5.7L V8
What’s the reasoning for sanding it?
T JAZ
T JAZ
Glendale AZ
hemi 5.7L V8
But yeah I’ve got some friends coming to town this weekend and we will ensure it doesn’t rub at any point.
ram1500rsm
Trabuco Canyon, CA
Take a picture zooming out to show the angle of the CV vs the coil spring retaining cone. Weird that it would rub the cone.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
If you run sand paper on it that should give you the clearance needed. Its barely touching and will stop it from hitting in the future. I would also take a little black paint and touch up the coil over. They are zinc and clear coated, Fox recommends we wax them with non abrasive automotive wax
Also are you able to move the axle at all? might be a bearing issue allowing it to move. See if there is any wiggle
T JAZ
T JAZ
Glendale AZ
hemi 5.7L V8
Its already not touching anymore, at least on rest. The groove has already been worn. No axle movement.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Get in there with some black paint. You don’t want any issues with the aluminum
T JAZ
T JAZ
Glendale AZ
hemi 5.7L V8
Oh so coat the worn spot on the aluminum? Got it.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Yes there is clear coat on them for protection, so you want to make sure you get a coat of paint on that exposed aluminum
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
How's the ride now that you have the factory race series all the way around? I know the fronts are night and day
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
What is the height of your garage door 84”?
JB1
Houston, Texas
Yes, you may be ok with the 35’s but these 325’s measure 34.5 on the truck so it’s like an inch higher. After reading your measurements I went out and measured mine with a level to make sure. It’s no big deal though, my goal was just to run a little smaller tire than the big 37’s
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
How’s the ride with the 6112’s set down, do you feel a noticeable difference? The guy I sold my eibachs to has a 6” Zone with 3” rear coils. I told him to lower them to 2.75 before he installs in hopes to not be close to it’s max preload
JB1
Houston, Texas
The 6112’s ride very smooth, with this new setup it’s like a whole new truck. I still want to get the Fox coilover some day, waiting to see y’alls finished
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Glad to hear I knew they rode good before. The Fox are quite impressive they have surpassed the expectations I had of them. I’m hoping to log some miles on them this weekend.
JB1
Houston, Texas
I bet they ride great, as long as I could adjust them to approx 5” to 5-1/2” lift I’d get a set
ROYSZZ4
