Front Sway bar brackets
BigDogDiesel
So.Fla.
cummins 5.9HO
Anyone have sway bar brackets they cut off from a stock 2500 or have had this same problem.
If you installed a lift kit you may have cut off the stock brackets in order to install drop brackets for your new sway bar
Please I need a pair or an idea to replace.
I’m running a early 2007 2500 and need to reweld the stock brackets in order to use my new Thuren sway bar kit
Previous owner installed a tuff country 4.5lift which I’m removing and going with Thuren 3” coils, track bar, sway bar, long travel leafs,fox 2.0’s & synergy steering T style upgrade
Any ideas would be appreciated
joshhhh
