Would someone please post the torque specs for the front end?
HangmanNY
FL
Fellas,
I’m going to be replacing the lower control arms, inner and outer tie rods, upper control arms (with CORE 4x4 UCA), new Eibach Pro lift springs & Struts. Also Suspension Maxx heavy duty adjustable sway bar end links. Also new wheel hub/bearings.
And I have a new heavy front sway bar which should arrive on Monday. I ordered new brackets for the new Moog bushings.
The rest of the parts should be arriving in the next couple of days.
Would someone please let me know what the torque specs are for these components ? I have a 2015 RAM 1500 Big Horn.
I’ve had cardboard under the truck and I’ve been spraying all of the bolts and nuts with PB blaster for the past two days. Hoping that everything will come off relatively easy.
Thanks for any helpful information.
Jacob Maguire
Pine Beach NJ
Hemi5.7
from the pinned threat atop this sub-forum:
Chassis Torque Specs - credit goes to brandonjansen for this
(4th Gen RAM)
Shock Absorber Upper Nut --------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -------------------------------------------------------------100 ft lbs
Shock Tower to Frame -------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque------------------------------------------------------ 35 ft lbs
Lower Ball Joint Nut Final Torque ------------------------------------------------------148 ft lbs
Upper Ball Joint Nut -----------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts --------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut------------------------------------------------------------ 200 ft lbs
Upper Control Arm Frame Nuts --------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ----------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket------------------------------------------------------------ 110 ft lbs
Stabilizer Link Stabilizer Bar Nut --------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)------------------------------------------ 110 ft lbs
Stabilizer Bar Nut (Power Wagon) -----------------------------------------------------110 ft lbs
Hub/Bearing Bolts -----------------------------------------------------------------------149 ft lbs
Axle Nut - 132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) -------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) ----------------------------------------------------200 ft lbs
Tie Rod End Nut ---------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -----------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws -------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -----------------------------------------------------170 in lbs
Dynamics Sensor--------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt ----------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle ---------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud--------------------------------------------- 200 in lbs
ABM Mounting Screws --------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts ------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings --------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ----------------------------------------------200 in lbs
Brake Booster Mounting Nuts ------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts ---------------------------------------------------------160 in lbs
Reservoir Retaining Screws ----------------------------------------------------------------6 ft lbs
Caliper Bleed Screws ---------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front -------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear --------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) -----------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) ------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) ----------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) ----------------------190 ft lbs
Junction Block Bolts, Front (1500) -------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) --------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) --------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) --------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) ----------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) -------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -----------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) -----------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -----------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear ------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ------------------------------------------------------7.5 ft lbs
Brake Hose Fitting ------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ---------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) ---------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) ---------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) --------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) ---------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ---------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) -----------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ---------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ----------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) -------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) ------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) ----------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) -------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) -------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ----------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------148 ft lbs
Spare Tire Winch --------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt --------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt -------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts --------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower -------------------------------------------------160 ft lbs
tburger
