front wheel speed sensor wiring ripped out by running over a stick
Forest crumpler
mami
I found the abs/wheel speed sensor cable hanging loose. the connector is fine but there is nowhere to plug it in! there is a cable protector sleeve attached to the firewall but no sign of wires. I think the wires were broken at the point where they enter the main wiring bundle but I cant find where that point is.
anyone have close up pictures of that area. It is covered by the air cleaner box.
Any help will be much appreciated.
Forest crumpler
Forest crumpler
mami
An update: I forgot to mention that the wheel speed sensor wiring in question is the right front.
Forest crumpler
Forest crumpler
mami
Is there anyone out there that could provide a pictureof the wiring underneath the air cleaner box? I need to know where the right front wheel speed sensor wire enters the wiring bundle.
thanks much!
huntergreen
Marine Corps Navy Badge
Sorry, can't help, but I think you will get some responses in the general discussion section if you post this to question there.
spakram
PA
i have the exact same issue. i replaced my passs front hub and to my wonder no wire or connector at all i need some help too im taking to a trusted tech tomorrow morning maybe i can help then
rdsawyer
KS
Same problem but my right front tire blew out and took fender liner and right front wheel speed sensor wiring with it. 2011 5.7 hemi Big Horn 4 wheel drive have no idea on where the wiring went to. I replaced the sensor but where does the wiring wire into
Domi2
