Fuel filter cap
sredbeard
Western Ma.
cummins
Could someone tell me please what size socket I need to remove my 2013 6.7 fuel filter housing cap?
Power247
High Point, NC
6.4 HEMI
If your talking the filter up beside the motor it is 18mm
Sent from my LG-V510 using Tapatalk
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
Make sure you get a 6 point socket for this. I tried to use a 12 point, cause thats what I had on hand. It didnt work very well, and damaged the cap.
OLEJOE
N. La
6.7 CTD
I think it is supposed to be a 28mm. And as has already been mentioned, use a 6 point socket to keep from rounding off the plastic nut.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
If you get the oil filter cap your all set for easy routine maintenance
The dealer does it for about $18 more than I can do it for, so they get that pleasure. Plus it gets the truck in regularly for visitation.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Lucky you. Dealers around me still think changing the oil on an ISB is worth $150 and $500 for the two fuel filters.
Jus10case
