Fuel sensor fail.
Sled Freak
Perth County Ont
16 ram with 86000km and the sensor started going wonky on me.
Ram wants $230 for sensor and 3hr labour another $300.
So question is, are there aftermarket sensor available and where's the best place to buy? Rock auto has no listing so....
Sent from my SM-G960W using Tapatalk
Boston, MA
2014 Crew Cab
5.7L V8 HEMI
Allmoparparts.com
Contact Benny. For just the fuel level sensor approx $120 or the entire pump (level sensor included) approx $310. Dropping the tank is the labor part. Depending on mileage, they recommend to replace the entire pump so you do not need to drop the tank later $$$.
There is several threads regarding this costly failure. Very frustrating, mine failed also and I only use top tier premium gasoline. Good luck!
Sled Freak
Sled Freak
Perth County Ont
Allmoparparts.com
There is several threads regarding this costly failure. Very frustrating!
I did a quick search and found 1 thread. Seems to be a known issue I have realized. Just trying to find a cost effective replacement. Might tackle it myself but need the part first
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
With that many miles you can get the entire fuel pump assembly for $70. Easy swap in 2 hours dropping the tank.
Here is the one I bought, flows more and has a more robust sender. Purchasing another mopar unit will fail again in short order.
Maxfavor Fuel Pump Assembly... https://www.amazon.com/dp/B07P6B5QFR?ref=ppx_pop_mob_ap_share
Sled Freak
Sled Freak
Perth County Ont
85000 kms is alot? My 08 had 150000 on it and a wheel bearing is the only thing that was replaced. This is premature in my opinion
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
I was referring to replacing the pump sock especially if using garbage 87 octane with ethanol that is the main cause of the sender failure.
joshhhh
