Addicted2fishing
- Jul 2, 2017
- 3,077
- 2,821
- Location
- Durham region
- 2017
- HEMI 5.7
Hey folks.
Today I finally installed my two rocker switches. One is not hooked up yet as I plan on hooking up rear lights. But I wanted to wire my bull bar light up.
Issue is I don’t want constant light on the switch so o wanted to tap into the cigarette lighter/12 v plug as it’s ignition only and as far as I know we don’t have have blanks with power.
I bought a mini fuse tap but it didn’t fit. What style or size tap should I look for ?
Also, does anyone know if this is safe ?
I am using a relay harness that came with bull bar/light. It has a + And - off light bar. Goes to a relay which goes to 12V power source and a harness that goes to switch. Do I need to wire power to switch separately or can I use the power from fuse tap to power light bar? I’m an idiot when it comes to electrical. So instead of using positive and negative off battery use negative off battery and positive (hot) in fuse box? I’d have to cut the batter connector off the positive and add a fuse tap.
Thanks!
Tiped on ifone using Tapatalk and auto correct. Can’t you tell?
Thanks!
