Gas to diesel
Dfarmer15
360 magnum
All the lifts that are 3in or greater say for v10 or diesel only I have a 99 2500 with a 360 what is so different and what is a lift to look for
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Weight technically.
Generally speaking, if you have a 2500 you won't notice a difference at all.
Hell, I know a guy running diesel lift springs on his "1500" and says it rides fantastic.
D
Dfarmer15
360 magnum
So there isn’t a difference in suspension
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Not the bare bones of it. Diesel and V10 springs are merely stiffer in stock form, and in aftermarket form, the diesels are offered in more lift sizes.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
The springs largely are the same size, just the V-10 and diesel are slightly thicker and stiffer. But then again, so are many aftermarket gas springs.
Some people say V10/diesel springs make the ride a bit too stiff in the front, others say it rides amazing and handles heavier tires better. Largely how it handles is going to ride on the shocks you use. I put the heavier duty springs on my truck when I replaced my rear leafs. It lifted the front about an inch or an inch and a half, I didn't measure. But you do notice a slight increase in height. Its not a lift though, you could get the same change in height by dropping tire pressure by 20psi.
