Gear Ratios
fuelman99
I have 3.92 limited slip gear ratio in my 05 hemi. Is this a good set for the 1/4 mile or should I look into 4.10s or 4.56s?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Thats an OK set-up to start with but if you decide to move up go 4.56 as goin 3.92 to 4.10 is a waste of dough IMO!
Ask RT-VA, he did the 3.92 to 4.10 swap an he will be the first to tell you that he wishes he had gone 4.56.
truckin151
2013 sport
Still trying to figure out your wheel spin issues since you shouldn't really have that much of an issue as it stands now. But if you swap out the gears go with the 4.56's
onebadbee
from what i noticed going from 3.92s to 4.56s is a trade off
3.92s help in the top end and 4.56s help down low in the end the et dont change much in a 1/4 mile cause of the offset
now in the 1/8 its a huge difference
fuelman99
fuelman99
I ordered some traction bars to start off trying to eliminate the excessive spinning. The only time I need gears for the 1/4 are on the street. All of the tracks we have are 1/8 mile, so 4.56 would probably be a good idea. But my truck is an everyday driver, I know 4.56s will hurt my gas mileage, but how bad?
truckin151
2013 sport
They don't hurt it at all. Mine went up in the city and as long as im not goin over 75 it went up on the highway by about a mpg too,
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
IMO, 4:56 is the only way to go with our trucks. Especially if you have 33" or bigger tires. I have 30.5" tires and as stated wish I had gone with 4:56 instead of 4:10.
fuelman99
fuelman99
What brand and where can I buy some?
Redtruck-VA
Virginia
As for differentials, I went with Detroit TruTrac and really don't think there is much difference in quality between Auburn and Detroit. However when installing the 4:56 gear with a DTT there is no pin to contend with so I feel the DTT is a better way to go when using the 4:56 gear. I didn't realize this until all of the recent threads on pin grinding came up. So it does seem DTT has an advantage over the other differentials.
onebadbee
no clutchs pack or springs in a detroit
hands down better unit
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
thats an opinion.
they're both gonna lock up virually instantly every time. they're both never gonna wear out (i say never loosely -- obviously they will wear out, the auburn a little faster because of the clutch packs, but it takes FOREVER -- longer than you'll be driving the truck thats for sure). the advantage over the DTT? the install like RT_VA said, but then 90% of us dont do our own gear installs anyway, so thats irrelevant. the advantage for the Auburn? Its $100 cheaper.
Auburn won for me and i havent EVER wished i'd gone trutrac.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
had 3.92's, changed to 4.56's (loved it even though I was running shorter tires...30"), changed to 4.10s and regretted it..now back on 4.56's and lovin it ever since..
Knice12
