general maintenance questions
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
where in the holy hell are you getting oil changes for $10 or $15!?
My dad did his at the dealer with both fuel filters it was $300... (obviously going to be higher with fuel filters i know...)
I think he means paying $10 to $15 extra for them to do just the front drive shaft grease. That is least how I read it.
cc rider
Western NY
I was referring to greasing the drive shaft. I always change my oil myself.
avolnek
2015 Ram 2500 CCLB
they'll charge you but there won't be an grease in that joint
Fact! been told by multiple dealerships my trucks havent ever had this grease fitting!
mike456
mike456
new york
cummins 6.7
i was planning to do a tire rotation along with air filter and grease, my thoughts were diagonal or X pattern, my mechanic says front to back? any thoughts?
loveracing1988
Clarkston, MI
Always cross the non drive wheels. So fronts cross to the back and backs go straight forward. A FWD car would be the opposite.
mike456
mike456
new york
cummins 6.7
my mechanic cant find points to grease on tie rod ends
Road King
Southern Komifornia
6.7L Cummins
Due for my first oil change, and the dealer included lifetime free oil changes when I bought the truck :) But, I'm sure they plan to **** me on the fuel filters, so after a little poking around, I found this set on Amazon for under $100.
Decent price for the set - can't seem to find them anywhere else for cheaper.
Question; will the gauge automatically reset once I change the filters or is there a procedure to reset the gauges?
mike456
mike456
new york
cummins 6.7
its gotta be easy, the morons at my shop do it in ten seconds
i have my oil analysis, printed and rescanned with my personal info deleted but its saying the file is too large to attach to this forum?
Rotzilla
colorado
6.7 CTD
No you have to use the arrows in the evic to reset. Very easy to do.
mike456
mike456
new york
cummins 6.7
so i got the blackstone report back last week
did my first oil change at 3,000(dealer claims to have used synthetic)
second at 6,500(my shop mobil1)
third today 11,500(my shop mobil1)
the actual mileage was 4,800 from second to third oil change(got nervous about idle time), blackstone stated that my oil looked good, but was equal to that of an oil that had 6,900. there was active additive left.
said i can run close to their average interval next, dont know what that means
i dont know if im used to the truck or its just psychological but i feel like i lost power since around 10k
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
Can you redact your personal info and post Blackstone's actual report? There is other info and their exact wording of things that can say a lot more.
SouthTexan
408 CTD
You are not going crazy. As per your diesel supplement.....
"Because of the construction of the Cummins® turbocharged
diesel engine, engine run-in is enhanced by
loaded operating conditions which allow the engine
parts to achieve final finish and fit during the first 6,000
miles (10 000 km).
There is a definite change in performance once the engine is run-in which is why I tell people not to judge the Cummins performance based off of a test drive on a truck with zero miles on it. Mine was about 8,000 miles when I noticed it, but that is because I tow regularly. It may have taken longer for you since you idle a lot.
mike456
mike456
new york
cummins 6.7
i tried to attach the pdf to a post but the file is too large?
Road King
Southern Komifornia
6.7L Cummins
So I changed the fuel filters this weekend (after oil change). Saved a bunch of greenbacks doing it myself, but boy-oh-boy did I get diesel friggin' everywhere, lol.
Even with the handy drains built in, I still managed to spill it all over. Just be aware, that when you think the filters are drained, they are in fact NOT! heh
mike456
mike456
new york
cummins 6.7
ive got 12,000 miles and over 800 hours on the truck without draining the fuel filter once, does that seem odd to anyone
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
Here is mike456 oil report he sent me.
Mike, is this report correct that there is 11,338 miles on the sample or was that intended for overall vehicle miles?
mike456
mike456
new york
cummins 6.7
no, i have an amended report, hold on i will forward
OasisNinjaBat
