Getting a little FASTER!
THEBAD1
2003 Sport SLT QC2WD
Well, as the truck is not an every day driver ( for the past 4 years) anymore...adding some Performance Mods this Spring! Hope for 14.0-13.9 Street tirm.
List is :
1. TCI 2800 Stall - have
2. Richmond 4.56's - have
3. Auburn limited slip - on order
4. Yukon 1541H alloy axles - on order
5. SuperChip 3865 - have ( as my old one is ven locked)
6. Summit (Harmonic Damper SFI rated) underdrive pulley & Alt pulley - have
7. Flex-Lite 180 E-fan - have
8. Caltracs - have (getting Powder Coated)
Also adding:
1.Russell Street Legal Brake Lines - have
2.BBK Fuel Rails (Hemi Orange) -on order
3.Kenwood 516 DVD Headunit -have
4.Smoke Headlights - have
5.LED Halo Headlight rings - have
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
That should get you there with your dang factory freak lol. How does your truck hook on the street?
THEBAD1
THEBAD1
It all depends on the pavement.....smoke's them up most the time LOL!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Any wheel hop or does it plant good then blow the tires off?
THEBAD1
THEBAD1
Plants good...then blows the tires off. Also adding Caltacs to the truck...hope it helps with that!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Caltracs will tame the axle and give you consistant launches.
THEBAD1
THEBAD1
Awesome Dave! I think it's time to BOOST the Reaper!
Boost is not worth the "Headache's" .... just like getting BLOWN, it sucks with no tuning for the 03's. For what I had in the SuperChange setup (almost $9,000 dollars) I could of had a BAD ASS Stroker Motor!
THEBAD1
THEBAD1
Nice you are running MM Ported TB as not many are running them. Love mine.
Yes, and Dave Webber was the "Pioneer" of the Ported TB's. I went to other people and was told the Hemi TB's were at their limit. I meet Dave in 06 at a Mopar Event at Virginia Motorsport Park. We talked for some time and he asked if I would like to do some R&D work for him, I said sure! It was running and testing the MM ported TB's. After Dave did this everyone jump on the ported TB's but, I say his TB's our the best out there! I say this because of over 50 runs I did with his TB and others ( not going to say names) and I always pick up time with his TB.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
That's a hell of a list! Wish I could gather all that up for mine.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Cool. I got mine through his ebay store and came within a week. Good mod.
Also purchased his 5.7/6.1 Adapter plates w/ thermal gaskets and the quality is top notch.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What kind of time difference where you noticin in the TB's? My fastman helped with mid and part throttle respones but cant say it changes much if any in times.
truckin151
2013 sport
My fastman dropped my times by about 0.05-0.1sec pre cam. It didnt want to play nice with the cam though so it pulled and the stocker was put back on.
Redtruck-VA
Virginia
I didn't really feel a difference when I installed a Fastman TB. Workmanship looks good.
THEBAD1
THEBAD1
His TB's work great! Others I tested, all I got was a little better throttle response as (most at the time) just cut the front face of the TB's. Dave's TB's had a more snapper throttle response, I got 1 1/2 - 2 miles more per gallon of gas (open road), on hot runs I was picking up 0.80 - 1.00 and on cold runs 1.50 - 1.80 in the 1/4. Also looking at the time slips it was working all throw the RPM band. I did 20 runs one day, 10 with the stock and 10 with the MM...every two passes I would go in to pits and change out TB's. On every run...and they were hot runs the MM TB gave me 0.80 -1.00 more in the 1/4 mile.
THEBAD1
THEBAD1
Hmm, what cam are you running? I have installed MM TB's on stock cams, 260, 268, with no problems? Maybe it was a bad TB?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Good info Dave, The fastman might have picked me up a .05 or so. I couldnt do like you though and compaire the stock to the ported back to back, my OEM took a crap bout 2 weeks after the first cam install and never had a before and after run time.
Similar threads
KAKA
