They were also behind some of the FE C-6's to.My Dads old 75 F150 was an oddball truck,that after he dug into with the ford rep from down east was supposedly a truck built for a magazine test.How it ended up on a dealers lot in western Canada,the rep couldn't explain it.The truck had the heavy duty 391 block/Holley 4 barrel and a dual point distributor.We found out about the block when Dad had to replace the timing chain,as the run of the mill 390 timing chain was differant and didn't fit the engine in the truck, he had to buy the timing chain for the heavy duty 391 used in the 3 ton and heavier trucks,it also had the heavy duty ribbed transmission case,and it had the ultra rare nodular iron center section in the rear diff.
Supposedly the truck didn't exist if you tried to build it and order it through a dealer,but according to the Ford rep from Detriot who actually looked at the truck and took the vin number with him back to Detriot,the truck had been built to be a magazine test truck,but he couldn't find out anything on how the truck ended up on a small town dealers lot in Alberta.All i know is i put that truck through living hell from when i was 14 to about 17 and it took everything a nutbar teenager could throw at it,and never whimpered,lol.
One day i came home,and the old man got mad as hell at me,when he found a crushed oil can under the 100 gallon fuel tank in the box that was full of diesal.Somewhere along the drive home through the local thrill hills,i'd had the fuel tank far enough off the floor of the box an oil can rolled under it,Dad was not impressed you might say,lol
Those were the days the factories were still building oddballs that didn't exist if you were to order something through the normal channels,but if you knew how to run the ordering system,you could still buy a really good truck
