- Jan 9, 2019
- 34
- 26
- Location
- Central PA
- 2014
- 3.6L Pentastar
All,
I know that this has been addressed quite a few times, but most threads do not have a resolution. We've been getting rain steadily for the past few days, and my driver's grab handle leaked water out of the top mounting hole this morning. I've noticed a wet circle on my mat in the past week, but I was puzzled until the water dripped on my leg today.
Truck specifics: 2014 Ram Bighorn Crew Cab with sharkfin antenna. I do not have cab lights or a sunroof.
Anyhow, after searching through thread after thread after thread, I'm going to try and diagnose what's going on. I found this little tidbit from @dav8388 in another thread, and I'm going to give the bubble test a shot.
Most of the other threads did not have a final resolution or follow up from the OP, but I will update this thread as needed.
Preliminary investigation:
- After hearing about the leaking third brake lights, I have noticed that mine doesn't seat very well. Also, there is some dampness around the back seat trim. I'm thinking this is part of the issue, but not all of it.
- Frequently during rain, I will get a cellular error on my 8.4 radio. My hunch was that the antenna was allowing moisture to get inside of it, and cause issues. I plan on checking this antenna for tightness and checking the seals as well. I'm thinking this also might be part of the issue, too.
- Door seal appears to be in good condition. No moisture found on headliner at the immediate vicinity.
- The windshield finishing trim on the sides was lifted slightly with debris underneath. I lifted this carefully out of the clips and cleaned underneath it. There is a very degraded felt gasket underneath here as well. Thinking this may require some sealant in the future.
This evening I'm going to try and check the sat antenna and third brake light for bubbles, and will report back.
Again, please do not suggest that my sunroof drains are clogged or pinched as I do not have one.
I assume your talking about the grab handle. Many things can cause that. Satellite radio antenna, sun roof drains, or a leaking windshield. Some say the third brake light but I don't see that leaking that far forward. One trick is turn your HVAC fan on high, close all doors and windows. Spray the satellite antenna, windshield trim, ect with soppy water until you see bubbles. Or I'd remove as much trim as I could and sit inside while someone sprays the outside with a hose.
