Grand Cherokee limited window switch
Dan98
I have a 2014 jeep and drivers side window was left down in a rain storm. Now only back Windows work on master switch. Switch work fine on all other doors. I replaced master switch i stile have same problem. Does anyone know what i should do??
Sent from my LG-M150 using Tapatalk
MADDOG
Living in a Firepit
6.4L HEMI
Check your connections for dirt, water and corrosion. Also test the motor.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Can you plug in the drivers side widow into the passenger side window switch to see if the motor is OK ? Also check connection for corrosion
D
Dan98
All connections are clean no broken wires and the switch only has one plug so I can't tes Drivers window with pass side switch.
Steve58
