Driver and passenger window issues
Outdoorsman1127
Alberta
( 2011 Ram 1500 Outdoorsman) Having a problem with my driver and passenger windows. When I take the key fob out of the ignition the 4 way flashers flash 3 times then the windows will roll down on their own. I put the key fob back into the ignition and turn it to accessory and roll the windows back up, then the 4 ways start flashing again 3 or 4 times and the windows roll down again. It usually takes about 4 or 5 tries before the windows will stay up. Also when I lock the doors I'll walk away from the truck and the doors will unlock on their own when the key fob is in my pocket. I have changed out the drivers window master switch twice and the fuses seem to be ok. Any suggestions on what to check next and how to fix it would be greatly appreciated.
HarryS
Air Force
Clovis NM
seems to be your key fob, and not anything in the truck.
electricalservice
