Ground Location for O2 Heater Control Circuit Bank 1 sensor 1
Southern Vermnt
I am looking for the ground location for my Bank 1 sensor 1 O2 Heater control circuit.
I am getting a P0032 HO2S heater control, Circuit High Bank 1 Sensor 1.
I have had the sensor replaced with a mopar oem one already.
I am going to check resistance on Sensor heater circuit tomorrow to verify sensor circuit is good.
I am hoping to check continuity from harness plug to ECM Pin 18 also.
There are two heater circuit wires, but only one on ECM, does this mean they merge into one at some point, if not where does the other side go?
Thank you,
Steve
Bloody_Knuckles
USN 81-86
Lebanon, TN
I believe one wire is the O2 sensor heater and the other is the sensing wire. The ground is through the body of the sensor.
