Hardware v1 need switched 12v under dash
scHemi
2009 RAM SLT Crew
As the subject states. I started my I install and need a switched 12v source under the dash anyone have suggestions on which wire I should tap?
Thanks
HolyRamBatman
Deep in the Heart of Texas
There are a few in the wires coming down the steering column. Depends on what your looking for specifically. There should be a manual for your truck on here somewhere in the 4th Gen. area. I will see if I can find it for you.
S
scHemi
2009 RAM SLT Crew
I'm just looking for a switched 12v source I can tap for my v1. Nothing special
UNBROKEN
2012 Ram R/T
I used the power point in the console.
S
scHemi
2009 RAM SLT Crew
Alrighty then the power point it is. Now to find the wires haha
kkreit01
Olathe, KS
Do you have the OE trailer brake controller? That's where I tapped mine. I searched all over under there. It was difficult to find a switched +12V. I didn't know how difficult it was to get to the cig lighter.
S
scHemi
2009 RAM SLT Crew
I do have the brake controller plug. I currently have my p3 plugged into it. Although I don't know if that is switched due to the fact that the p3 stays on after I turn the ignition off. Some say its supposed to turn off after 15 minutes but I have not left it plugged it in that long
kkreit01
Olathe, KS
Sorry for the late reply. There is a switched +12V on the small plug for the brake controller. There was also one always hot. IIRC, the switched wire was pink -- with green stripe.
Reticle918
