Burla
- Apr 28, 2012
- 27,489
- 57,621
- 2010 Hemi Reg Cab 4x4
- Hemi
The misfire code is what started the whole repair ordeal. After replacing the injectors and spark plugs the misfire was cleared he drove it a couple of days to make sure everything was good and was going to do a state inspection for it but when he went to do the misfire code came up and wouldn't clear off the computer. He told me to take it to a dealer to see if they could flash it since his scanner wouldn't clear it but other than that he said it ran a drove perfect. I went to pick it up had no lights on the dash showing anything wrong but it wasnt running right. As far as my mechanic he is a professional but he did it at his home shop since we've been friends since high school.
But these issues happened after he had it so I'm trying to figure out what's wrong so i can either fix it myself or just tell him what to replace
Do us a favor and ask your buddy what the misfire code was, if it is the p0300 range codes then you need to not throw good money after bad and address cam. I'd keep driving if possible to get a real good idea on what codes the truck is throwing, if indeed the other code is all you are getting then look at mds and ecm like he thought was. It is kinda hard when we get 1/2 a story, get a cheap scanner and mark the codes,, it will give you a correct path forward.
