Hazard lights won't stop flashing!
Briain52
Chandler, Az., USA
I have a 2017 Ram Bighorn who's hazard lights won't turn off and it's draining the battery. I removed the turn signal switch and disconnected it but as soon as I reconnected the battery the hazard lights came back on! Right now I'm at a loss as to what the problem is! Any suggestions?
tron67j
Maryland
I usually advise to not start replacing parts, but this might be a case to get a new switch and try it out. Couldn't hurt. Maybe replace the flasher unit as well. Contact Benny in vendor section All Mopar Parts. Good luck.
hazard lights, windshield wipers, turn signals, Hi/Lo Beam Headlights & maybe other things are controlled by the Multi-Function Switch on the left side of your steering column,, watch a YouTube Video or 2
Easy replacement, if that is the issue
Lemniscate_Mike
