HD Tire Pressure Monitoring System Reset
Status
Not open for further replies.
DIRTRIDER
2019 REBEL
HEMI 5.7
Any info on the '19 1500's yet ? I have a '19 Rebel that comes with LT, E load tires with a 55 psi rating for TPMS and would like to go to a larger diameter B load tire that would require less psi and would set off the "low pressure" lite. So i would like to lower my TPMS settings. Same as the '18 system ? I do have access to an Autel machine if that will work.
MajorMalfunction
NJ
Cummins 6.7
I used it on mine but I cannot connect to a 2018 vehicle.
Sent from my LG-H918 using Tapatalk
My understanding is that ANY 2018 Ram this will not work due to the new security firewall. You have to use a special security bypass harness. I also have a 2018 and I am trying to reset my TPMS. I just ordered a cable from Deereguy here in these forums. There is another thread regarding this topic and using the AlpahOBD software through your phone. This method appears to be a helluva lot cheaper than a $1000 diag tool or not being able to get your dealer to reset it for you. Also, you can pretty much get at any computer related setting in your truck to turn it off/on. For example, the 2500 doesnt have daytime running lights. With this software and cable, you can enable DRL by using your headlights, parking lights, or driving lights.
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
You are correct all 2018s required the bypass harness. To do the TPMS changes, you need the harness, AlphaOBD, and OBDLink MXBluetooth, and your 4 digit PIN from a dealer for your truck. There is a full write-up in the AlphaOBD thread. You can also use a windows based PC if you don’t have an Android device.
CapandBeard
Alabama
Changed the pressure perameters with the AEV procal...and the dealership will no longer...or is “unable” to accept the change in my computer...even though I used the old style TPMS sensors
4x4x4door
near St. Louis
Cummins 6.7
Dealers are rather useless especially when it comes to this except to get the key PIN code.
Sent from my SM-G965U using Tapatalk
Jaywoo
Ward, AR
2021 & 2018
Hemi 5.7 & Cummins
Mostly correct. You don't have to have the harness. Z-Automotive makes a module that clips in place of the FCA security module. Then you just use the OBD cable like everyone else. It's behind the radio, though, so it takes a few minutes to put it in. The only catch is to take it back out if it needs to go to the dealer.
CapandBeard
Alabama
that seemed to be my thoughts once I left with my truck after the stack of recalls were done
4x4x4door
near St. Louis
Cummins 6.7
I've confirmed that the Autel will adjust the TPMS settings on a 1500 just like the 2500's. 2018's require a security bypass cable and I'm sure the 2019's will too. The only questions remaining are will the 2019's require a different cable and is the security the same as the 2018's. Can you take a picture of the terminal blocks under the dash? To do so, remove the kick plate directly under the steering wheel and look to the upper left. The should be green and/or white and zip tied to a band of wires. I'd post a pic but that's not working out very well.
DIRTRIDER
2019 REBEL
HEMI 5.7
Took some picks per your request of my '19 1500, hope these are right pics.IMG_1015.jpg IMG_1028.jpg IMG_1033.jpg IMG_1042.jpg IMG_1061.jpg
BPMPVET
Cummins 6.7
My bypass will still work, I think. I use those green/white plugs.
4x4x4door
near St. Louis
Cummins 6.7
The 18 HD bypasses should technically work on the 19 1500s.
Hmmm ... maybe mine is not correct. Both white & green terminal blocks have the longer connectors that hold 3 wires. My cable has 1 of each so I think I need a rebuild. I'll send you a text.
Abraham
Nm
Originally posted by Snake_Eyes.
Edited by SuperModerator.
Default settings for HD TPMS systems are quite high. Some owners report they cannot find a desired tire size that will accommodate the higher pressures so they must make a choice between wearing out their new tires prematurely or dealing with constant EVIC warnings, a Low Tire Pressure warning light and a rough riding truck.
There is a fix.
This has been confirmed to work on any 2014+ HD truck and on any model. You will have this done at a dealer per the instructions below. It is recommended you print them and take them with you. The technician should be able to change your settings and turn off the light.
Step 1: Go into the BCM (body control module). Go to "miscellaneous functions". Go to "update pressure thresholds". Set pressure to desired settings. Do not try to do different pressures front and back! Even if you run 10 psi difference front to back you won't get a light. If you plan to run 10 psi difference I suggest your "setting" be in the middle of the high and low just to give you a little cushion.
Step 2: Go into the RFH (radio frequency hub). Go to "miscellaneous functions". Perform "RFH replace" and follow prompts. You will need the PIN number for the truck. That can be obtained through Dealer Connect with the vin number to the truck. When following the prompts - when asked for desired pressure setting - set new pressure levels. You do not need to replace anything - just perform the function to set new levels.
Once the RFH replace function is done the light goes out and the truck will read new pressures after driving a short distance.
More Information on HD TPMS Reset Options
This information was originally started & gathered in the CumminsForum.com thread How to set TPMS to ANY pressure which is similar to this thread. It has 1700+ posts with info changing half way thru and much confusion. 4x4x4door created that thread to help clear up confusion and help as many as possible. Special thanks goes to Indytruckchampion(CF member) for creating that thread with the process and to articsilber323 for figuring out that the Autel Maxisys can do this since FCA removed the ability from the dealers. PLEASE read the common questions below before asking questions.
General info:
To fully adjust the TPMS you need the change the psi thresholds and update the RFH (Radio frequency hub).
Factory pressure settings are 60(Hemi) or 65(Cummins) front & 80 rear with a 20% threshold which means that the warnings (light, sounds & nag screen) will come on at 48(H) or 52(C) front & 64 rear. If that happens then you will have to air the tires to 60(H) or 65(C) front and/or 80 rear to make the warnings go away.
The PIN – You must have your PIN to fully adjust the TPMS system. There are 2 PIN numbers associated with your key and truck. Technically, there's a 3rd one too that's a rolling code (unknown digits) that expires. It is only used if you lose all your keys and it requires a call to Lord FCA to get. I believe this is where some dealers get confused and try to tell you that the 4-digit PIN will expire. I've not heard of anyone saying that theirs expired when they tried to use it. A few members have been charged a fee to get the code. This ridiculous and I’d find another dealer, but I realize some don't have that choice.
PIN #1: 4-digit code (all numbers) that is used to program the key (fobik) to the truck. This is the one you need for this process.
PIN #2: 5-digit code with a letter in front (ex. M0000) that is used to cut a new metal key.
It’s a good idea to get both codes as soon as you possibly can. Recently, some dealers have refused to give them out.
Devices:
Autel MaxiSys -- will adjust the psi settings and update the RFH (Radio frequency hub)
Launch X431 -- very similar to the Autel MaxiSys with possible same functionality
Matco Maxgo & Maxme -- supposed to be able to adjust the psi settings & update the RFH (Maximus should also)
AutoEnginuity software -- will only adjust the threshold psi settings (also custom tire sizes & enable fogs w/highs)
Witech (dealer) -- will only update the RFH, IF you can find a dealer that's willing do it
AEV ProCal -- only sold with their lift kits; will only adjust the psi settings (tire sizes & other settings)
Snap-on – no one has found that any of their devices can do this
Common questions:
Q: Can the dealer do this?
A: They cannot change the psi thresholds but they have the ability to update the RFH. Whether they or not is questionable.
Q: Is there someone near me that can do this?
A: ***HERE*** is a map that 4x4x4door created showing all known members that have a device. If there'e no one close enough to you, try contacting 4x4x4door or BPMPVET.
Q: Will this ‘change’ get removed if I get a flash update from the dealer or if I install a tune.
A: No
Q: Will this ‘change’ void my warranty.
A: First they have to prove that it caused a problem and how they gonna 'see' it? The Witech can't get to the settings but anything's possible.
Q: What model of Autel MaxiSys can do this?
A: The common model is MS906 but any MaxiSys model should have this ability excluding Dodge software version 7.5.1. The MaxiDAS cannot do this process and I doubt any MaxiTPMS will either.
Q: Can the Autel MaxiSys make other adjustments like larger tires or enable fogs w/highs?
A: It’s a very powerful diagnostic device but it can only adjustment to other factory tire sizes and cannot enable fogs w/highs.
Q: Where can I find the instructions do make the adjustments?
A: articsilber323 provided these in post #912 in the original thread. Some of the screens have changed slightly with the newer software versions but the process is generally the same.
Finally got mine in to do this and it works fantastic!
All the individual sensor fault lights went off, the TPMS low pressure warning light is off and the initial power up chime no longer is heard.
I had my minimum pressures set at 50 PSI, cold temp pressures are at 55 psi in each tire. I've noticed I'll get 3 - 4 psi growth as the tires heat up at speed. So that works for the 10% cushion.
Abraham
Nm
Hello I have a question, I have a efi live tune on truck so my question is can you still move threshold on tpms 2017 ram 6.7
MADDOG
MADDOG
Out Exploring Arizona
No. FCA updated the tech tools and blocked access to that section of the BCM.
But there are two other tools I am aware of:
1. AlphaOBD
2. Autel
I don't know if EFI Live software can access the RF hub of the BCM.
4x4x4door
near St. Louis
Cummins 6.7
EFI does not affect the ability to change the TPMS settings nor does it have the ability to make the changes. As Mad dog stated, one of those devices will work.
If you don't have an Android device or know of someone with an Autel, give me a shout and I'll provide details for mailing one to you.
DadRich
Ocean Springs, MS
6.4L Hemi
So the Dealer can or can not do the adjustment on a 2018 2500 hemi?...............I had my new tires on for a week and 400 miles and it decides to do it today on a cold day............
1500ram12
5.9L Cummins
With the new security features that ram implemented techs don't have access to certain features. But with the smart people on these forums have found a workaround. @M2Mods sells a security bypass harness for $50 that, well does what it says and will allow you (I'm guessing the dealership) to make whatever changes you need or want to. Along with the bypass harness there is a app called alphaobd (windows and Android based program), cost $50 and allows you to change tpms thresholds add factory features and much more. The last additional cost is the obd2 reader. There is a Elm...... For around $30 that works and the one that most seem to have the obdlink mx (+) for around $60-90. Pretty much any android device will work, you can add Google play store to a Amazon Kindle if you choose that device.
Status
thoffmann517
