Headers or Gears ? ? ? ? ? ? ? ?
audio1der
Airdrie, Alberta
The problem is that you have a 4wd. You are going to need a factory LSD out back along with factory gears. Then you will need aftermarket gears up front along with both front and rear install kits. This is going to run you about $1200 in parts plus about $600 for labor. Shorties are considerably cheaper, but wont give near the performance gains.
So he can choose what he wants. As usual, you get what you pay for. Less money=less gains and vice versa.
Go for the gears!
torq
torq
NW Indiana
6.7 cummins
sounds like everyone has way different thoughts lol
Intrepidacious
Even with no other mods, going from 3.55 to 4.10 gears would be a dramatic improvement in measurable 0-60 both empty or loaded or towing. You'll feel and measure the difference at any RPM, at any throttle position. You'll feel the truck being much livelier even off-idle just accelerating mildly from a stop. Climbing any on-ramp, hill or mountain becomes a more casual affair rather than a strain.
Numerically higher gears help the engine at all times, both mundane driving and hard driving.
I don't think any of this would be true with shorty headers -- their advantage is at the top end. For everything else, mild-to-moderate driving and towing, the factory headers breathe extremely well. Dodge's factory horsepower and torque are very high. Do you think they accomplished that with a restrictive exhaust?
Motor Trend finds 0-60 was just 5.7 seconds in a short-bed 4x2 Ram that had the 4.1 rear axle, while 3.55 rear axle models have had 0-60 times 6.1-6.4 seconds. When you're starting with a vehicle that already does 0-60 under 7 seconds, another half-second reduction is hard to get with engine bolt-ons.
You might have more of an issue with occasional tire slip due to the better gearing, but you probably have limited slip diff and you have a 4x4 so I assume that won't be much of a problem.
(I assume part of the gear swap will be updating the engine computer with the new ratio information.)
