Headlight opinion
iam_canadian22
northern ontario
Im in a bit of a dilema, cant decide between black tyc projectors with hid's or retro my quads with mini h1's, the quads i would paint to match the truck too and if i chose quads theres the extra debate of doing my stockers or getting tycs to do for less downtime
xbxjunkie
going by my own experience, i had tyc projectors with morimotos and was pleased with them....for about a year. i got bored with the look and just recently sold them and going a different route. tyc makes a great reproduction, are HID friendly and they perform better than OE, IMHO
adurm
FL
2015 RCSB
You could probably knock out the quads on a long weekend. It would be cheaper. I think your light output will be similar if you ran Mini H1 in the quad vs FX-R in the TYC's. You will be better off retro'ing the quad opposed to dropping an HID kit into the TYC.
Ebay should be able to help find a temp headlight if you need. Or you can grab some OEM or TYC projectors for a couple hundred more. Whatever you do, you will likely need a relay harness as well. JJ at retroshop.us can hook you up. Also if you add TYC projectors to a quad based truck you will have an additional adapter to buy ($135?)
Using your quads, you might spend $250 for parts and paint? Getting TYC...300-450 for the projectors, $300 for the HID kit/FX-R and harness, plus $135 for the adapter.
Rough estimates of course. Opening those TYC projectors aint easy.
iam_canadian22
iam_canadian22
northern ontario
Ya ive delt plenty with hids in these things, no issues with the harnesses, and opened a few sets of stockers, tyc's are said to be easier then oem although if i went tyc projectors i wouldnt do a fxr retro for quite a while due to the extra cost, i like the looks of the tyc/factory projectors better but a real retro in the quads would yield better lighting results for now
iam_canadian22
iam_canadian22
northern ontario
Basically dileme is go for tyc projectors with hids in em to have a more modern look with the led signals and have effective lighting and retro later on or the more dated quads but have top notch lighting now
Raadz
