Headlight, Turn Signal, Hazard and Fog Light Issues
Nathanagreen
Virginia Beach
2014 5.7L.
My headlights stay on regardless of what position I have the cabin selector switch in. At no point do my fogs work, at no point do my turn signals work, at no point do my hazards work. Also my high-beams wont come on either. On the dash cluster, all indicators appear normal, i.e. if I turn on my left turn signal, the indicator flashes normally, same for hazards as well as fogs, but again none of those lamps actually work.
I've taken a look at the TIPM, I cant find any relays that appear bad, nor fuses that are bad. I've removed and cleaned the cabin light selector switch and cleaned it, that did not fix the issue. I can hear and feel a relay in the TIPM when I have my hazards on, however, the lamps dont actual flash
Break lights work just fine as well as reverse lights.
Is there a fuse panel in the cabin on the 2014?
Any ideas?
2018NightRam
LA
Not sure about ram specifically but a lot of cars do the switching / controls in the actual switch. Might be a bad switch
RamCares
n/a
n/a
2014 5.7L.
Any ideas?
Hi Nathanagreen,
We are certainly sorry to hear about these concerns you are experiencing. Have you considered addressing this with your dealer? If you decide to go this route and need additional assistance we are available through private messages!
Laura
Ram Cares
