turn signals
  1. A
    Turn signals
    When I bought my 2013 truck in December neither the mirror turn signals nor purple lamps worked. Found a faulty puddle lamp lens on the driver's side and ordered replacement mirrors for both sides from Amazon. Lo and behold they were made in China and after installation found they vibrated like...
  2. WillT
    tow mirror signal lights quit working
    Hi, I have a 2015 Laramie Ecodiesel with tow mirrors, I noticed about 8 months ago that my driver side signal light on the mirror quit working and now the passenger side quit as well. I have noticed a small crack on the light on the driver side, but there is no moisture inside and the passenger...
  3. O
    LED Grille Lights w/integrated turn signals
    I'm installing some grille lights with amber turn signals to my 2021 Ram 1500 Bighorn. I need to individually tap into the front left and front right turn signals. I tried to tap into the fuse box under the hood for each individual side, (F09 and F10) but when I do that both of the new turn...
  4. Underground Lighting
    Black Friday Sale Is Now Live Save Up To 20% All Orders!
    Its that time of the year again, when you can get huge saving on all your lighting needs! Enjoy 15% Off all orders or 20% off all orders over $300 Our Kits are Plug and Play Error and flicker free for all Ram Trucks. Need help finding the right Lights for your truck message us we are here...
  5. R
    Issue with LED rear turn signals.
    Hello everyone, I had my LED factory tail lights go out and decided to replace them with aftermarket ones. Everything works fine, the truck is configured for LED already but I still get turn signals (both sides) out. But they physically do work normal. Here is the error code I keep getting on...
  6. Ellis32198
    Hyper flashing LED Signals Only with Headlights on?
    Hey! I know this subject has been exhaustively discussed over the years, but I have not been able to confirm the next step for a solution. What I understand about retrofitting turn signals with LEDs: - Obtain and utilize AlfaOBD to designate low impedance bulbs, or - Use inline resistors to...
  7. Barney556180
    LED Turn Signal Install Problem
    Hello all, I installed a pair of 3157 LED Tail/Turn/Brake bulbs along with 50w 6 ohm resisters on my 2014 BH. Everything works correctly on the passenger side with no errors. However the identically installed driver side has issues that don't make sense to me. The LED blinks at the normal...
  8. Copa20
    1998 Turn Signals and Brake Lights Not Working
    Working to get my recently inherited 1998 1500 operational enough to sell, and am having issues with the turn signals; none are working. The headlights and tail lights work, only the blinkers, hazards, and brake lights are not working in both front and back lights. I have replaced all bulbs and...
  9. Tony Graham
    Right Turn Signal out per EVIC. New Bulbs don't fix.
    I have a 2016 RAM 1500 that is having some weird electrical issues. The EVIC keeps telling me that my right real turn signal is out. I have no tail light, no turn signal, and no brake light. However, when I unlock the truck with the key fob, the light flashes so I know the bulb is good. When...
  10. N
    Headlight, Turn Signal, Hazard and Fog Light Issues
    2014 5.7L. My headlights stay on regardless of what position I have the cabin selector switch in. At no point do my fogs work, at no point do my turn signals work, at no point do my hazards work. Also my high-beams wont come on either. On the dash cluster, all indicators appear normal, i.e...
