Hello, looking for a little advice/direction on a heat issue.
issue: Since it started to get cold up north I noticed my heat has not been working well. At low fan speed the heat comes out of the front vents at about 140 degrees F. As I turn the fan speed up it comes out cooler. By the time I get up to full fan speed it is still a little warm but it isn't going to cut it when the temps really drop. While sitting at idle it is cooler than when moving. I know a little bit of that is normal, but it gets much cooler than it should at idle.
All of the controls work. Wherever I direct the heat, it goes there. Floor/defrost work but the temp stays the same. The hot/cold dial (is it called the thermostat?) works as I can go from cold to hot and the temp changes. It just doesn't get real warm on higher fan speeds.
However, it does seem to get a little warmer when I put the fan in "max" mode. Not sure if that is a figmant of my imagination or not.
I flushed the heater core twice (just flushed with water, no cleaner). It seemed to make it a little warmer. The path seemed clear to me both times I flushed it. I can blow through it very easily and it doesn't seem to me like there is any restrictions. While flushing the core I noticed I had a small radiator leak. I replaced the radiator and thermostat and that hasn't help out.
One of the hoses going to the heater core is definitely warmer than the other one. The hoses are set up so that there is a larger diameter hose coming from the coolant reservoir that goes into a tee with smaller heater hose coming from one side of the tee to the heater core and the other side of the tee going to the engine (water pump?). The other heater hose from the core goes directly to the engine right next to the other hose. The hose that goes directly from the heater core to the engine is warmer than the other hose with the tee. It gets hot enough that I can't hold onto it for more than a few seconds.
I don't understand how the coolant is supposed to flow. Can someone explain that to me? Also, any ideas as to what I can look at next? The coolant I drained out on the radiator replace was the original coolant (10 years old). The truck has 65,000 miles. The coolant and everything else I looked at was very clean and I didn't get any chunks out anywhere.
it is a 2003, 4.7.
If you got this far, thanks.
it is a 2003, 4.7.
