Radiator coolant level
Cummins593500
FL
Cummins 5.9
Is the radiator in a 3rd gen 5.9 supposed to be filled to the brim when the engine is cold? the expansion tank is full and I just bled all the air out of the system using a coolant funnel kit. Took it for drive then checked the radiator after it cooled down it was about 1 to 2 inches below the filler neck is that normal for these trucks?
no leaks on the ground and no milky cap or dipstick
Heater core is bypassed
Should also mention it’s a new radiator truck heater exchanger had failed and transmission fluid mixed with coolant. Radiator, transmission and heater exchanger was replaced
jws123
nj
Sounds like a radiator cap not letting the coolant suck back in as it cools off.
exactly this replace your rad cap and make sure your overflow is not clogged.
C
Cummins593500
FL
Cummins 5.9
So the radiator cap was bad I replaced it and it is sucking back from the overflow tank had to bleed it again but radiator is staying full now
