heat only coming out of winshield vents
dodgeman1980
5.2 liter 318
I have a 1998 dodge ram with the 5.2 liter v8 318 engine and the heat only comes out of the winshield vents no matter if I switch the controls to different spots on the heater control please help me as the cold weather is here so I can get this fixed as soon as possible.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Do you get any air at all out of the other vents? Is there a hissing sound when you turn the vent selector?
D
dodgeman1980
5.2 liter 318
No I don't get and sounds at all when I switch the heater controls.
dudeman2009
Magnum 360
Then i'd start by checking the vacuum lines in the engine bay, one of them is either cracked or disconnected.
Marksman
1999 Ram 2500 4x4 SLT
V10
I want to say that the vacuum line that feeds the controls enters the cab on the passenger side of the engine compartment around where the ac lines and heater hoses go through the firewall.
dudeman2009
Magnum 360
Yes it does, right off the intake under the airhat.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
I have a similar problem. My heat works fine on all settings but if I'm heavy on the throttle, the heat stops flowing until I let off the throttle again. I think that this is often referred to as "wild vents."
dudeman2009
Magnum 360
Your problem is due to one of two things. A bad check valve, or a really bad leak. If your vents change strong when you are light on the throttle, then i'd go with the check valve.
montrese04
somwhere, In
1999 single cab 4x4
5.9L
So what y'all are saying is there us a bad line that connects to the knob on the dash? And this line allows your blend door/vents to change settings.
Would this be why I have no gradual change between heat and cold settings? Everything works as far as vents, cool g and heating. I just don't have the option for a gradual setting. It's either hot or cold when I select
Sent from my HTC One_M8 using Tapatalk
dudeman2009
Magnum 360
The blend door is either cable driven or servo driven depending on year, it is not vacuum actuated. To tell what your blend door is doing, look in the passenger footwell all the way left.
The attached picture is if you were looking in from the passenger door.
Right where the little servo attaches you should be able to see a shaft, that should rotate smoothly.
SSGTD
