Heat went out
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
Perfect timing(-7f) for the heat to go out on me. The cluster is telling me the engine isn't budging from 130, and is supposedly below that. I know for a fact its getting warmer than that though. I even blocked off the radiator to see if it would warm up and didn't. My dad said he talked to a dodge mechanic who told him that I may need a whole new cluster, a new water pump, &new temp guage. My dad was thinking he was saying to get a whole new cluster. Just throwing it out there to see if any of you guys had an ideas before I spend money on it.
MoparMagic'00
Arkansas
5.2 Magnum
do you have heat? is thermostat opening? if so it may just be a temp sensor...
mitchbowers
mitchbowers
Ohio
5.9 Magnum
I have no heat. Run the truck for around 20+ miles and will get slightly warmer than the air outside,but nothing you would want blowing on you.
Arlucian
Port Angeles, WA
Thermostat seems likely since youre not overheating. Is your lower radiator hose hot? not warm but hot. First thing id check is thermostat if your fans are blowing fully and its lukewarm air.
mitchbowers
mitchbowers
Ohio
5.9 Magnum
Pretty positive its the pump. New thermostat put in today, but yeah that top hose running into the water pump is hot, ice cold bottom hose.
rowdyram
magnum 5.9
There is no way I can reason that the pump would cause "over cooling" the thermostat and fan clutch are the only two possible causes aside from some crazy witchcraft
mitchbowers
mitchbowers
Ohio
5.9 Magnum
Pump replaced, manually stuck open the temp guage door and she'll throw out some heat.
Dee907
5.9 magnum
did u check your coolant to much coolant will make u not have heat i always do 70% coolant 30% distilled water but u can always use 50/50 mix as well im in texas thats why i do it cause its so hot in the summer here i like a cooler engine but not to cool my needle always sits around 170 to 180 everytime
Nixonjgreg
