Heatwd steering wheel
bigbadwolf2018
Moose jaw sask canada
2018 ram stx 1500 classic
Hi rammers so lets get to the problem
2018 ram 1500 gas ive recently up graded my leather heated seats got new panel switch installed everythi g works as i gotmy harness made from m2mods now heres my prob i bought a heated clock spring with the heated steering wheels hooked it all up and push the heated steering wheel button turns on then off push again turns on then off. Does it need to be alfa obd Programmed to turn it on ? I have a V linker mc+ and the alph obd licensed to get into settings but says i need the blue wire which is what do i need a securty by pass cable to get into the settings? What does it look like and where to by one of these i ve searched the web and all i found was it needs to be activated in the alph obd settings can some one guide me through this thanks
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Go here, for security bypass cable
