Hugorhr7
New here. Been having issues with my Ram after gassing up. It idles and chocked after I gas up. Been thinking it might be the fuel pump but wanted a second opinion before I pull the trigger. Cleaned the throttle body, switched EVAP Purge Valve, and
ESIM / NVLD Leak Detection Switch since i previously had the P0456 Code. Light turned off but truck is now acting up when gassing up. Thank you in advance for the help
