Hella 500FF w/ HID'S How???
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
i got a set of hellas mounted behind my grill, i just got my h3 hids from ddm in,
anyone know how to install them while still useing the reley that came with the hellas? and can i still use the switch?
4x4Hemi
Edmonton, Alberta
You just have to splice it in there haha does that help???
You have to cut the plugs off the ballast and connect them to the power wire on the relay. You can still use the stock hella relay and switch. You just have to determine the power wire going to nlights and splice the ballast onto it.
I'm sure my vague answers dont help much I wish I took pictures of the process when I did it
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
so i just splice the current wires i have now, w/ buttconnecters? ground and power?
4x4Hemi
Edmonton, Alberta
basically yes. id solder them together for strength and since their out in the elements but butt connectors work as well. as for actually gettin the bulbs in there, do you know how to do it ??? JJ has a thread somewhere
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
io heard drill a 7/8 hole in the middle, i dont know how to solder so ill just use connecters and elec tape.
Darkknight3829
to replace the bulb? you dont have to drill. There is a screw in the back that you just unscrew and the bulb comes right out
4x4Hemi
Edmonton, Alberta
Its not replacing juat the bulb. Theres different wires and grommet you need for hids
gibby252006
Can you do this with Piaa 510 and 540?
Steve58
