Help for alfaobd
Kor_JeongYeon
South Korea
Hello.
I'm running 2015 Ram1500 Rabel in Korea.
I joined the forum to solve various problems
I would like to ask you first about the two problems below.
1. Currently, the ABS module is broken in my vehicle, so the parts from the US to Korea are I'm on my way.
After replacing the module, what settings should be performed through alfaobd
I want to know exactly.
2. I know that the bed is usually higher than the front for pickup vehicles.
However, the rebel is an air suspension, but I don't know the reason for setting it like this.
So I want to set the front and back the same height
Is there any related data?
ex) I am using MX+.
John Jensen
San Diego County
Ecodiesel
Here's the procedure for my 2016 1500, Ecodiesel
First, clear any faults
Run ABS initialization:
Car Model> Ram 1500> Function> ABS> Select Control Unit> ABS Bosch/Continental/Teves/TRW Powernet My"years"+ Powernet> Connect>Select Hood Open icon> Select procedure> ABS Initialization> "Start"
RamDiver
Marlborough, Ontario Canada
2021 DS
Hello.
ex) I am using MX+.
The standard levelling fix is to install Bilstein 5100 struts up front, set to +2.1" but I'm not familiar with where to begin with an air suspension rear.
Also, the levelling mod will be different depending on the intended use, pavement Princess or offroad use.
Try searching levelling or levelling 1500 in the search utility in the upper right corner.
There are many members and vendors here who are experienced with levelling.
And, welcome.gif to Ram Forum. :cool:
markabby
Monticello, Kentucky
2020 Limited
welcome to the forum!
maybe resetting the air suspension will level it out using the alfaobd ?
Kor_JeongYeon
Kor_JeongYeon
South Korea
Thank you for your detailed reply!
I think we need to set up VIN after initializing ABS module, is that correct?
Kor_JeongYeon
Kor_JeongYeon
South Korea
And, View attachment 556846 to Ram Forum. :cool:
Thank you.
I think I found a way to set it by looking at multiple threads.
First of all, since I usually use normal mode
I'm thinking of adjusting it horizontally from that mode. :)
Kor_JeongYeon
Kor_JeongYeon
South Korea
Thank you for your welcome!
I've been looking for a lot of information
It has been confirmed that the four heights can be adjusted through alfaobd.
There is a video I referred to, so I will share it with you.
