HELP! P0205 and P0305!!!!
Tr3y
Canada
OK, so the cylinder five misfire is being caused by the injector issue. I know this already my injector is stuck open and it is dumping fuel. I have load tested all of the wiring for the number five injector all tests come back good I have tested for a short to ground on both the pink and brown wire all testing comes back good I have tested for a short to power on both wires. All testing comes back good I have swapped the injectors around quite a few times as well as cleaning them and the issue does not follow anywhere else so I’ve ruled out that it’s the injector but I’m still dumping fuel at this point. I’m thinking a corrupted PCM? But I’m not sure I’ve just redone the cam and lifters all gaskets throttlebody all the breaking and a radiator I don’t know if this really has anything to do with it. I thought maybe I had pinched a wire somewhere but that wouldn’t explain why all of my test so far have come back good. I don’t know if there’s anything else I can test all of my fuses are good. All of my wiring is good. The only thing I really think at this point is the PCM , but any help any solutions? Anything else I could maybe try?
RamCares
n/a
n/a
Hi Trey!
Thank you for bringing this to our attention. Our team would suggest bringing this to your dealer's attention, if you haven't done so already. Feel free to private message us with any updates or questions.
Gia
Ram Cares
Bob Templeman
