Help Vibration During Acceleration
MBofTexas
I have a 2014 1500 Express with 5.7 Hemi. I have 6" lift done by Regency hear in the DFW area. The wotk was done for the dealer prior to my purchase. My truck was purchased new last month. I have BF Goodrich All Terrains KO. 325'S Which I believe are equivalent to 35's give or take. When I push the gas with mild to high accerlation I feel what I would call a vibration through the gas pedal. I spoke with Matt at Moe's and he has a similiar issue. Any thoughts or ideas? Thanks
jwheeler
Washington
I would take it to the dealer. But if you want to try and figure it out, I would inspect the front CV angles. Too steep of an angle can cause a vibration like that. Or the pinion angles. Is there no vibration at steady speed or light acceleration?
M
MBofTexas
No vibration at steady speeds and slow accelerations.
M
MBofTexas
Pro Comp
RamWrayzor
Sin City, NV
Is there a spacer on top of the rear spring? The reason I ask is the most complaining comes from lifts that place the big spacer on top of the spring, especially during acceleration.
Doc1609
Missouri
I could feel a slight vibration in the gas and brake pedal when I was running Nitto Trail Grapplers. It felt like something wasn't right, but it was just the lugs of the tires. Not sure you'd have those issues with an all terrain.
Johnn123
Ontario
^I got the same thing when I switched to my MTZ's. Never noticed it with AT's though.
OP get a pic of the cv angles and the pinion angles and post them for us. I have also heard the top coil spring spacers can cause a vibration on acceleration. Is that how yours are installed?
joshhhh
