Help - will 2017 dodge ram 1500 tailgate fit a 2018 ram 3500 dually 4wd
arcars
FL
I busted up my 2018 tailgate on my 2018 ram 3500 4wd dually ---- found a replacement but says it is from a 2017 Ram 1500
will this fit my vehicle ??
says its equipped with backup camera and power lock --- which I can remove from my busted up one and swap out --- but was not sure if it would work or not
thanks!
I also found a 2019 ram 3500 tailgate ----- but in my research I think the 2019 is 5th generation and WILL NOT work --- correct ??
Brian2081
Weatland Michigan
17 will definitely work, 19 should also. Buddy of mine has a 21 2500 and he put next to my 16 2500, body wise the front clip is the only thing we could find different.
SeventyGTX
Yep, all the Gen 4s are interchangable no matter if it's 1500, 2500 or 3500.
A Gen 5 may work, but wouldn't look right. Not sure on that though.
Fatboy1989
