Help with 2WD Lift!
X Justus X
Argyle Texas
PowerTech 3.7L V6
Okay so I am soon to be getting a 3" Body lift. I am wondering if that is going to level my truck out aswell, and if it dosn't then if I put a 2.25" Level kit on it will that basically mean I got a 5" total lift? Also I can't get new tires until these ones are done i think they are 265/70/17. If I do get a lift will it look bad with these tires, and what size should I get when I get new ones. Also what are coil spacers?
Thanks :favorites13:
SmokedRam
Zephyrhills, Florida
No, the 3" body lift will not level factory rake...only way to do that is with the suspension...
SmokedRam
Yup! That would work fine...as for it looking kind of bad, the 265/70-17 is about a 32" tire...it probably would look kind of weird til you got bigget tires...you can clear 35" with just the level and no body lift.
Jus10case
