HELP with alfaOBD
Rpols7
NJ
I reprogrammed a used ECM and it starts and stalls right out. The vin and injector codes took to the unit, but will not run. So I reinstalled my ECM and it does the samething
R
Rpols7
NJ
I should include that its a 2016 eco diesel 3.o
Sdpadrez
I would reach out to alexey with help with the bcm modules
Lildikgang
Houston
Could I use alpha obd to change code that’s not allowing me to use a key fob my factory key is metal it’s a 2019 Ram classic
Tach_tech
5.7L HEMI
You also have to do the PCM replaced function in the WCM, should also do the throttle relearn, make sure the VIN is updated to the PCM as well.
JayLuke
SO CA
CTD 6.7L
I've used alfaobd to program key fobs on a 2019 ram 1500 classic, but you need a bypass cable
gville35
