Help
[email protected]
I have a new 2016 ram 1500 crew lariat
No problems until I lifted it with only 2500 miles on it .. A RCX 6" lift with 37's .
It Has a out of balance tire FEELING from 40 which is very mild then 50-60 worse and 70 it's pretty bad. Have changed the rear springs, added adjustable rear link bars to get more angle on rear, shaft seemed a bit flat. Tires have been balanced and re balanced, road forced balanced .
It's been all put back to all original 6"lift components since nothing has fixed the problem..
Have someone telling me to hook a tuner with just a speedo fix that tha cpu is messing up?
Someone telling me my pinion is loose.
Any ideas?
Csanders1992
What tires are they?
OilfieldLife
Eunice, Louisiana
Could you possibly need an alignment? I've had a similar problem but it was due to caked up mud in the rims lol easy fix. Maybe when you went try out them new tires still have some cakes on mud? That's assuming that you did test them out.
Steve58
