Hesitates before starting
yingchu
florida
Before when starting the truck it immediately turned on after turning the ignition key. Now it briefly coughs or chugs a couple times before starting after turning the key on. It has a new battery so am wondering what is happening and if this a problem that will only get worse?
Michigan BIGHORN
U.P. Michigan eh
5.7l Hemi (obviously)
Mine does that too only once in a blue moon and only when using the remote starter (aftermarket). Doesn't seem to be any issue with mine.........
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
My 2011 1500 started to do this as well. Wondering if it a common thing or not. Glad you posted!
bigdodge
I started to have this issue and replacing the battery solved it for me. While it may test good it's just enough to make it crank more to start
Sent from my Pixel 4 XL using Tapatalk
