HID Issues!!
VADER
Colorado Springs, CO
So. I tried to tackle a new project this past week.. With help and advice from other threads here, I managed to crack open my headlights and paint the guts a gloss black to match the truck. While I had these out I decided to put in some HIDs!
Problem: I hadn’t seen anyone on here running two sets of HIDs, both for high and low beams (I have the quad lamps) so I’m not sure if that is something I should be doing… I tried this set up.
Initially every light turned on. Put the driver side headlight back into place and the lows/highs worked when queued. Sweet! Put the passenger side in, they worked too. Started up the truck and began to drive home…
The lows stopped coming on entirely, so I drove with the highs. They worked for a few minutes then the driver side turned off and the passenger side was flickering… suddenly, lights out. Luckily, I still have my fogs so I was able to get home safe, thank you lord baby Jesus.
SO! WTF guys, what happened?? This is my first experience with HIDs. Am I not supposed to be doing both highs and lows? It doesn’t make sense to me at all, this is why I do not mess with electrical ANYTHING!!
My kits were from Xenon, locally bought. Both 6k @ 35W.
Has anyone had this issue, or do y’all know what I can do to fix this tragedy? Anything helps! I have been a lurker for a couple years now, but I am a huge fan to the site. I know, I know.. I should’ve just got hooked up with JJ in the first place… Next time.
iam_canadian22
northern ontario
rams need a special canbus relay harness in order to work properly, cantact him you can get just the harness and they will work with your hids
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
^^bingo
and there are no issues with running them in the highs and lows. do it to it!
joshhhh
