adurm
Hi guys, need some advice. I have a set of tyc projectors in my 2015 RCSB that JJ did a couple months ago. They worked fine until I was driving home last night. I was making a right and had my signal on. Made the turn, the signal kicked off after I straightened out but the headlights shut off and would not come back on. Pulled over. Shut off the truck and started it back up with no resolve. The LED turn/driving lights still turn on. Fogs come on. I can even turn on the high beams (halogen, not the bi-xenon).
Once I got it home I poked around with the wiring. Got power at the OEM harness at the drivers side. Could not get power at the input for the ballast. I contacted JJ because his customer service is amazing. He offered some suggestions but he too was stumped.
Since the OEM headlight plug has power but the wire leading to the ballast does not, there should be something wrong with the relay right? If I lost a ground connection, would that cause a zero voltage reading on the wire to the ballast?
I was looking for a headlight fuse but couldn't find one, that was before I tested the plug. I ran a new power wire for my amplifiers on Monday. Lights were fine on Tuesday.
Any suggestions would be appreciated.
