joshuaeb09
- Apr 5, 2016
- 1,426
- 2,402
- Location
- Medina County, TX
- 2022
- 6.7 Cummins
we get killed on prices on everything here. less demand, less population and lifts are speciality products so they appropriately are expensive as hell. initially in reading through your whole thread today and some others, I thought i could just do biltsteins on the front and spacers in the back for a level basically. i can probably get the hardware to do those for like 400 bucks then labour on top (i don't have everything i need to do suspension work) but...wondering if i just do that if i'm missing something important in the equation. I would rather do nothing than cause complications. I looked at the Rough Country spacers all around solution for like 250 bucks worth of parts, 358 kit i think it is... but that seems too budget and sounds like its a recipe for stress on the front end that I want to avoid.
am I making any sense? LOL
It's really gonna depend on your use of the truck. If it's mostly highway, no heavy accessories, and occasional mild stuff off the pavement then the 5100's aren't a bad choice. Just know they're not really a badass off road performer, but I will say they are better than stock on and off road(Mostly on road). I wouldn't, however, go past notch 4 (2.1") if you value the ride quality as you'll be putting a lot of preload into the spring. Out back spacers are fine and I've run my 3/4" spacer with the stock springs, stiff ass 1211 springs, and now the softer Billstein +1" springs. When it comes to spacers upfront you've got more to consider that's been covered in depth, but pretty much anything bigger than a small spacer can lead to issues with the stock suspension bits along with certain spacers just being a **** poor design that leads to damage(Hodge has a thread on this). If you want a slightly better ride quality I would get rear springs over a spacer, but depending on what you go with you might need longer shocks, brake line bracket extensions, etc. If you stick to the 1" springs or a max of a 1" puck you'll be ok with the 5100's, but a better ride/performance can be had with more customization obviously.
In my case I'm running a hodgepodge of parts all combined together with the weakest link being my 5100s and the immediate goal was to get the front back off the ground with my heavy bumper, riding a little better, and alignment specs more conducive to running a 35X12.5. Eventually I'm going to upgrade to something better in the shock department hence all the upgraded components on my truck (TTX HD LCA's, JBA UCAs, TTX HD Rod Ends, Core 4x4 adjustable 5 link, Carli Panhard Geometry correction). I also live out in the middle of nowhere with horrible roads hence the desire to upgrade to something better than 5100s for my daily driving. When I go into the city and its all highway the current setup actually rides pretty damn well compared to what it was and the better/smoother gravel roads are fine up to about 55-60 mph. If I only had to venture out here occasionally I'd probably leave it as is due to how well it rides in town and on the highway.
The final product is in the Eibach thread and I have a few images floating around the Eibach issues thread of the parts and what not. It's sitting on 275/65R20's currently and eventually will get 315/70R17's at some point.
https://www.ramforum.com/threads/eibach-pro-lift-struts.130255/page-31#post-2041804
